Preppypyro
I bought a trailer the other week. Its a tri axle, and the marker lights do not work, not 100 percent sure about the electric brakes, and the right side stop/signal doesnt work.
The trailer has a car battery mounted on it which kinda stumps me. Also when I ripped the old trailer plug off, to install a new one, there was a few wires that werent in the "correct" place in relation to where the plug instructions said to put them.
Heres the wiring that came with the new 7 prong plug
1. white - common ground to terminal 1
2. blue - electric brakes to terminal 2
3. green - light to terminal 3
4. black - battery charge to terminal 4
5. red - stop and left turn signal to terminal 5
6. brown - stop and right turn signal to terminal 6
7. yellow - auxillary ground or auxillary circuit to terminal 7
Heres where the wires were on the current trailer plug.
White wire - terminal 1 (correct)
blue wire - terminal 2 (correct)
green wire - terminal 6 (incorrect)
black wire - terminal 4 (correct)
Red wire - terminal 7 center terminal (unhooked)
Looks like this is the wire that was rerouted to the battery
brown wire - terminal 3 (incorrect)
yellow wire - terminal 5 (incorrect)
Do you think I should just go and hook up the wire to the plug where the instructions say to?
Instead of just trying that should I go rip apart all the wiring and trace the wires to be 100percent sure?
Right now the rest of the wiring is kind of hidden, and it will be quite abit more work to get at it. I was just hoping to figure out the plug first then if need be, tackle some more.
Any tips, hints, or advice would be appreciated
