That was fun getting the bearings back in the cage but with some red grease I glued them in. The axle shafts flanges were of different sizes so I put the old axle shafts back in and all is sealed, I now have 4:11 gearing wehooo. Now on to pulling the PTO and hydraulic motor off transmission cause transmission is next.Remove the snap ring and bearing from the output shaft port in rear of front housing, install drive unit then install bearing, snap ring and seal. Don't try and shove thru-shaft through bearing.
Maybe that's what snapped the ring gear tooth off, whenever it all broke loose.It's really not that unusual to find broken welded up crossmembers on older trucks.
Got the transmission out and will say the jack and it's modification didn't work. Weight of the transmission pushed the plate hard enough to snap the bolt holding it through the plate (1/4 inch plate), guess I should of welded it. Tried using how the jack was made instead of fully modifying it as needed and almost cost a broken arm or death, heed this warning.
Was pulling it with ratchet strap attached to cross member, jack was holding not a problem but when the input shaft came loose all hell came loose. No pictures but will post something of this whole escapade later of either or of what is going on for update.
Thanks, you and me both. I thought something was going to happen when that input shaft left the clutch just didn't know what and surely didn't want to be near when it did.Man, glad you didn't get hurt or worse.
Time to hook up the welding machine as I hate having to, (very time consuming) and go mad scientist on this welding fabricating to hold the next one going in better. Not going to have 583 lbs drop on me or whatever next one weighs.Your dealing with close to 600 lbs with 9 and 10 speed models about 780 lbs with a 13 speed.
I know of a fellow who only has one hand. Must be careful. You can't get away fast enough.
Thanks I will incorporate that into my design. Pulling bell houses off right now, new transmission/engine mounts will be in on Tuesday. Got polyurethane ones instead of the old fashion rubber ones.Ass end of the trannies are the Heavy spot, all the clutches and extra casing. Needs to be about 60/40 or 65/35 Back end MORE on the jack.
Output shaft support bearings are toast, which is unusual. A possibility that somewhere in that transmissions history the rear section had been into and the spacer between the output
support bearing was left out. The chipped tooth on the auxiliary drive gear is uncommon also, I would suspect the rear main shaft support bearing has some major play. The front
sliding clutch for third/seventh-forth/eighth has seen some major miles. The usual thing to cause output bearings to go bad is a loose yoke nut but even then it takes a bunch.
I would have to agree with both of you as the neighbor who gave me the Peterbilt was scratching his head on the problem as he has been in few of these transmissions and seems as such with questions he asks, ideas he gives and tools he has. Would this website be worth of giving me the history of the rig?Looking at the synchro end of that chipped gear, it passed something as all have little disruptions along the face. I agree on a bad Rear Section build and install.
With older equipment it's just expected.
