OzDozer
The top rollers are correctly termed "carrier rollers" or "support rollers". There are at least 4 different part numbers for the carrier rollers, depending on tractor serial number, so you need to produce your tractor serial number to get the correct carrier rollers.
When you've found your S/N and the correct roller P/N from the above link, then try a search using the P/N, prefixed by "Komatsu".
Sometimes you get better search results, searching "images", instead of text results.
You could try calling Costex, they specialise in cheap Chinese products which will be just fine for your needs.
Otherwise, try Machinery Trader or Rock and Dirt, and search for Komatsu D41S's being parted out, or for used carrier rollers for the D41S.
Carrier rollers only carry low loads - you can even use blocks of hardwood as top support for the track chain!
Trim the bottom roller flanges that are hitting the pin bosses, with the gas axe - install 4 new or used carrier rollers, and you'll get several years farm use out of that worn undercarriage.
CARRIER ROLLER D41S-3 S/N 6001-UP Komatsu Part catalog
k-part.777parts.org
