Mobiltech I think you are 100% correct, have worked machine hard for over year and no problems, put a prv on and external ground strap b/c 315 ground issues, just tested standby pressures and got big clue and suprise, have been wrongly thinking it was forward most pump all this time, hooked gauge up to forward pump, standby has 400lbs at idle and 550 at wot, this actuator I pulled 2 shims out of, hooked to rear pump and standby has 1000lbs at idle and 1600 at wide open throttle, all these reading are in neutral no functions activated and did pull lthe actuator on left pump this morning and removed the two shims just like other actuator, so have extreme high nfc on left pump, think your bleed down theory correct, this machine was county machine that why low hours and according to my ET scan ecm matches gauge
