Wabco scrapers at work
Scrub Puller
Yair . . . G'arn Showpony four or five hundred bucks is'nt scary. LOL
I ran one of those Jiggers on the Gold Coast a while for Nuemanns, it would take a twelve inch cut in coffee-rock now that was scary!
Cheers,
Haddy
Atiamuri New Zealand
earthmoving contractor
Last contouring job we did worked out at $1.50 m3 loose and that was at a nice steady pace
stangoodman
New Zealand
Im after some electrical info that someone out there might be able to help with. It is info for a 333FT,222G and 111A models.
Firstly on the generator side....
1- generator AMPS
2- Generator Voltage
3- Frequency in Hz
4- Full current load
Secondly on the elevator motors
1- Motor AMPS
2- Motor Horsepower
3- Full load current
4- Rated voltage
All our books avoid getting into this detail however it must be in someones records.
We would really appreciate it as the modern day electrician can't believe how they work in dust, water and crap!!! and don't understand the system.
We are looking at putting new contacts and wireing on but they want this info first.
Cheers:confused:
Brainzie
New Zealand
1- generator AMPS
3- Frequency in Hz
1- Motor AMPS
2- Motor Horsepower
4- Rated voltage
Cheers:confused:
Is this what our looking for or do you already have this info ? out of our 111a operators manual.
Brainzie
Haddy
Hi Stan . Try Rotorua Auto Electrical . They got a older guy there who used to do a bit of work on these . Also Ken Bleakley ( who I got my 111A from ) from Taupo knows the 111A well . I haven't got his number but I can get it for you if you want . Haddy
Haddy
Stan , Brainzie has got Ken's number . I gave it to him a while back . A couple of weeks ago I buried my phone and lost all my numbers . Haddy
stangoodman
New Zealand
Thanks Guys,
That was a help but still after more on the elevator side as well.
Also was the 222 and 333 the same?
I tried Noah but he was tied up with some monkeys that he had to deliver to Terexkerry!!!
terexkerry
new zealand
wabco scraprrs
Thanks Guys,
got the monkeys they are out on hire operating 252s,spud jokes aside try Phil Gowenlock mobile 0061732175498 he might be able to help,good luck,kerry
stangoodman
New Zealand
A few photos of a palmerston Job last season.
Really wet clay that required discing in the cut and fill to get 10% moisture out of it.
Lots of hair gone on this job!!!
stangoodman
New Zealand
Just a few more different shots.
Real crap ground!!
Im sure a terex would have got thru!!! Year Right
terexkerry
new zealand
i see your dad there crying as he knows he has moved more yardage on his tracked dumper than the THING clapped out beside him
terexkerry
new zealand
have you any pictures with them actually with a load,probably asking a bit much.should put a shroud over them like nick so when the MIGHTY TEREX pass you can hide your attempt of making out you have a load in them
D6 Merv
Coromandel Peninsula. New Zealand
Self employed bulldozing contractor with a D6D D4E
You guys are going to kill me with laughter here :notworthy
Kerry you know the reason why some of those Wabcos go so well ? The "General" provided the puha to make them GO !!
