I would start by removing the stem of shift solenoid SC. Make sure you don't have any damage to the o-rings. Then I would swap that stem with that of SE . So you're switching 2nd with 4th. Also, keep in mind, the loader will almost always start in second gear, unless the load or incline dictate otherwise. Make sure the gear you are feeling is the gear you are in. Verify by observing the instrument panel. You can be preselected in F4 but start out in F2 or F1. If your clutch pressure is low but hasn't gotten worse, I'd say the clutch pack and seal rings are ok. I'd be looking hard at the stems vs the magnets.
I attached a little light reading for the meantime
