I have a Volvo ec240blc that i really hope someone can help me out on . To try to make it short this is where I’m at.
1. Lost signal to EMC ( said on monitor)
2. In manual mode machine died ( few days later)
3. Dealer came out said the ECU and v-ECU was shot .
4. I replaced both with new ones
5. I replaced engine wire harness also cause they said it was in bad shape.
6 . It cranks in manual mode now , go to auto mode still says ( no signal to ECU )
7. Dealer came back out and said grid heater is shorted .
8 I replaced grid heater
9. Still no signal on monitor.
10. Dealer said to replace pre heat relay and the auto/manual switch .
11. Did that today with no change.
As long as I’m in manual mode it cranks and runs fine. Switch to auto mode and still runs fine with everything working but says no signal to ECU. The starter will only engage when turning key in manual mode. If I turn the key when in auto mode I only hear the relay in fuse box behind the cab clicking .
Also I have replaced the starter safety switch that located right above the starter.
I don’t want to run it with no signal to ECU because dealer said that was what got the ECU and vecu the first time.
Thanks for any help u can give.
