Volvo A25 off road dump shift problems
Discussion in 'Other Earthmoving Equipment' started by Nathan573, Feb 6, 2020.
  1. Nathan573
    Nathan573 New Member
    Dec 11, 2016
    2
    Nc
    Mid 90’s A25 6x6. We got at auction. Worked great till today. Just stops pulling whenever it fells like it. Maybe mid route or stop to load or unload it decides not to move. Shut it off, start back up it will works fine till next time it does it. Do not have any experience with these trucks. Seems to be electronic. Any ideas??
  2. truecountry
    truecountry Senior Member
    Sep 25, 2007
    390
    Shop Manager and Tech
    clarksville va
    Check voltage at batteries for a dead cell and also check alternator voltage 26 plus volts ,This machine has to have 24 plus volts to shift but that being said I have seen the microswitches in shifter go bad ...hope this helps
  3. sfrs4
    sfrs4 Well-Known Member
    Jul 22, 2013
    162
    parts admin
    Great Britian
    Is it a genuine ignition switch? the transmission ecu takes a signal from the ignition switch that people often don't realize when fitting aftermarket ignition switches
    truecountry, Mark250 and funwithfuel like this.
  4. Nathan573
    Dec 11, 2016
    2
    Nc
    We have put new switch from volvo. Been through shift selector checked ohms per the shop manual. And load sensor. Ohm our harness per the book. Tried to buy new controller Volvo said discontinued so we are going to let them flash it. Next step red rag, fuel tank, match?!
    rmllarue91 likes this.
  5. rmllarue91
    rmllarue91 Senior Member
    Apr 17, 2014
    499
    field technician
    northeast pa
    It's a Volvo it needs a transmission.... I prefer centrans for exchange if you take good care of it you should see 10k hours out of it before doing it again
  6. sfrs4
    Jul 22, 2013
    162
    parts admin
    Great Britian
    check where the loom runs through the back corner of the cab, they are known to rub/chafe into the loom sometimes
    Vetech63 likes this.
