Hi all, further to my previous post, I thought it may be important to add the following details (and hope for comment..)
The transmission oil does not appear to be getting hot. It has been changed and is clean. I have reconnected the factory trans temp gauge and it seems to correspond to an ir thermometer both at the sender location at at several other locations around the transmission, and I am happy that the oil is not overheating.
The transmission 'drops out of gear' at operating temp, approximately 68c, at idle.
The transmission will disengage at idle, however, does engage fully with some throttle. There is no lack of power - It engages with an obvious thump
This furthers my thought that the transmission itself is not cactus. Is there some sort of valve that will return to tank or similar that may be effected when hot? Perhaps a spring, relief etc?
I have (a while ago) changed the filter, and cleaned the pickup in the trans, and not convinced that either of these are the problem.
Thanks in advance
Thanks in advance
