Volvo 4400
antz
Aust
I have recently purchased a BM4400 circa 1985 loader and I am having a few issues with the transmission when things warm up (20 mins of work). The transmission is reluctant to engage and when it does it is usually with a hard thud. When it does grab a gear it seems to have plenty of power, with minimal slip (will just spin the wheels). I have just replaced the trans and drop box oil and cleaned the suction filter. New oil I have put in is straight 30w about 22 litres and about 3 litres of 50w to top it up to full as I ran out of the 30w. There was some confusion with what is suitable oil, and im not sure if i have the correct stuff in there - volvo dealer here told me 10w40 and another mechanic told me straight 30w and another fella i know thought it should be 10w. I also have a transmission pressure light on when things are warm and no throttle is used. Upon initial startup the transmission behaves and shifts nicely (save for not going into 4th). The gear selector is all electronic.
Thoughts / comments appreciated.
funwithfuel
Will county Illinois
Mechanic
SAE 30 is ok if you never dip below 50 or 60F . If you have any suction leak at all, the pump is gonna have a hard time pulling oil up over air. 15w40 is what we use here in the states, it covers all your temperature ranges we would expect to see. Just make sure none of your external hoses are cracked/ sucking air.
When time permits, I will dig a little deeper.
funwithfuel
Mechanic
When you say you cleaned the suction strainer, did you remove the bottom cover and physically remove it? There's an o ring on that pipe to promote a tight seal. That feeds straight up to the lube pump driven by the torque converter. Be absolutely sure that is a good seal. On the left side hidden by the shift solenoids is a lube filter canister. Filter number 4787923. That could be why your tripping the trans oil light. Aside from that, it just sounds as though it is having a hard time getting primed first thing. Lighter oil viscosity and a filter change might be just what's needed.
antz
Aust
There is a round cover that contains the drain plug that i removed. I pulled the suction filter out and cleaned with compressed air and brake cleaner. When i reinstalled, i just pushed the pipe back where it came from. it felt like a good seal but i never checked for an oring (felt like it pushed into a seal). Does a blocked filter bypass or would it prevent flow? I have a replacement, but i hadn't found where it belongs yet.
What external hoses are you speak of specifically? is there any way to pressure test the system?
funwithfuel
Mechanic
If you climb in ahead of the axle on the right side of the transmission and look forward you should see a large canister housing Below and behind the shift solenoid valve bank. That's where you are filter goes. F memory serves it's only about 1/2 bar that sense that sensor off.
antz
Aust
ok thanks i will check it tonight. with regard to the oil, it isnt supposed to run atf was my bigger issue?
BigWrench55
Somewhere
I suspect trash in the valve body of the transmission. If you say it takes a while to select a gear and then when it does it's pulls strong. Then I believe that you have some sort of debris in the valve body. If you have a bad pump and low pressure then it would slip. if you have a clutch pack with a blown piston seal it would be slow to engage, but it will slip. if you have changed the oil and filters and still have the same problem. Then that is where I would start looking next. I say this from experience. Had a similar problem with a zf transmission. Boss told me to pull the transmission so he can open it up and fix it. I asked him if we could pull the valve body first because that's where I thought the problem was. I only wanted to look there first because the customer said he had this problem after replacing the pressure sensor and stripped the threads. Long story short. I pulled the transmission. Boss opened it up and found nothing wrong. I then meticulously went through the valve body and found a small shard of steel in a orfice of the valve body. Put some pressure gauges on it. If you have good pressure readings then I would really suspect problems with the valve body. Good luck and I hope that this will point you in the right direction. post a serial number and I might be able to help you with more technical information about your transmission. The machine is old and I'm not sure if prosis will go back that far but I can try.
antz
Aust
Ok. a few more things i will need to check. It also doesnt seem to engage 4th gear, not that i need to use it.
Doest the fact that this only happens when it is hot rule out some issues like sucking air etc?
antz
Aust
Ok so further to the above, I have changed the trans oil for 15w40, new filter as well. The oil that came out was surprisingly black given it has done less than 50 hours. Would this be indicative of excess slip in the transmission, and what can I do about it? Additionally, the transmission issue hasnt gone away once things heat up, so i can rule out oil and filter.
thanks
BigWrench55
Somewhere
Does it smell burnt? If so then yes excessive slippage will cause heat and burn the oil. And if that's the case then it's rebuild time. Nothing to fix that other than new clutches and seals. I would replace bearings and go through the torque converter as well (bearings and seals also). Also have the transmission cooler sent out and cleaned. Heat is a transmission's worst enemy.
antz
Aust
So this is a cab off box out job... no good. Is it something that i can do myself? The only place that i know of within driving distance wants $15k to rebuild my box.
antz
Aust
Sorry, to be more specific, I’m quite handy with a spanner. Question is can I rebuild the box myself or am I stuck with the 15k rebuild
BigWrench55
Somewhere
If you have ne never done a job like this before then I wouldn't recommend it. If you have access to the service manual and have the rebuild procedure then do what you feel comfortable doing. But I will repeat if you haven't done anything like this then I wouldn't recommend it.
antz
Aust
Ok well that counts me out. I haven’t got the experience let alone the manual to be ripping a tranny apart. 15k is a lot of cash though. The Australia tax.
funwithfuel
Mechanic
Have you looked for salvage components. You may find used take outs for much less. I don't know how it is where you are, but that's big business in North America.
antz
Aust
I have only found one machine in Australia being wrecked and it’s that way because it had transmission problems. The parts people I have spoken with suggest that my only option other than rebuild would be to import one. That kind of stuff, if available is drug money generally here. If the transmission was common to other otr it is possible that I can find one however I haven’t a clue if that is the case.
funwithfuel
Mechanic
Either I or one of the other fellas with access to the parts catalog will look it up to see what else it fits in. Hope to have an answer for you tomorrow.
