.... And if you have ever run a large dozer, you know there is pretty much no feel when fine blading with it.
........ According Jerry a grader guy should beable to do his job blindfolded.
...... So when I say visability I don't mean that.
Well D575, it sounds to me like you still don't get it.
Point one on blade feel
After push loading a few hundred thousand yards on a job years ago, I was asked by the foreman if I could grade house pads with the D-9H I was running. My comment was " I have done hundreds of them with a D-8, only thing is with a D-9 it will not take as long." I then graded an average of 20 pads per day till they were done. after seeing my work, the foreman sent home the smaller dozer that was only doing about 8 per day. I did not have any problem "feeling" the blade, and it was plenty loose at that. just load it up a little, and it steadies right out. Without a good feel, I don't think I could have got all those pads to +/- 0.10ft
Point 2 on seeing what you are doing.
A few years ago, on a night job my 14G had only one light on front and one light on the back. No moldboard lights or cab mounted lights.
I had a half mile to cover with 4" of crushed rock. After dumping the proper amount in the proper spacing on the whole road, I got on the blade and worked it by feel. When we cored it in the daylight, there were only 1 or 2 places in 1/2 mile 60 ft wide that needed corrected, so I will take your blindfold offer. I would not reccomend this as a standard practice, but only bring it up to show whats possible with the right ATTITUDE.
Point 3 on visibility
If you are now claiming you were talking about something else, let me just say not to talk about it in code, because it sure sounded like not seeing the blade was your problem.
Deas
I love your replies. You have certainly been around. Im sure we could swap dozer tales for a long time.
I havent had as good of luck climbing n the old cats like you say, but mine all had a multi shank ripper back there changing the balance and hanging up on things. Without that, I can definatly see a climb like that.
I like going up to a vertical bank, cutting in at the toe and dragging the material back under you repeatedly till you raise yourself to the top. I did it once on a 20 to 25 ft tall bank in a slope, so I could not doze any material to it to make a ramp. I kept undercutting it till I got to the top. At one point, the ledge hung over the hood of my D-8H, and loose rocks would fall on the hood and roll down at me. I would use my left hand to swat them away, as I used the right hand working the blade up and down to slowly slice more off.
Those were good times.
