Do you have a specific one in mind?12V electric is the way to go, no need to have the service truck close to the machine or messing with inverters.
Just a small pump with cig lighter adapter or alligator clips to hook on to the machines batteries.
It looks good.This little puppy will pull 20"+ on full air and it is whisper quiet. For sensitive things like plastic tanks I just regulate the air going into it to regulate how much vacuum I want out of it. It is a shame that Milton doesn't make this anymore. The best vacuum tool I own.
Kennedy makes one the shop I worked at used them. You may find one on the interweb. Also years ago before we had a pump we put a tee on the brake booster line on service truck and ran a hose from there to hyd. tank to pull vacuum.Looking for a 12 volt vacuum pump for hydraulic systems. Deere has one and Wirtgen Group has one, but I would rather get one from a third party if possible. Has anybody ever gotten one elsewhere? Also, is putting a vacuum on a plastic hydraulic tank an issue? Does it need to be regulated, and if so what is the best way to do that?
