Tuff-studds or Tung-studs
dabsfabs
Somerset, UK
Hi
As any one had experince with either of these products.
As have a clinet that has ware rate rates of around 400 to 600 hours for dozer corner shoes, what i can work out is that these products may help this dozer keep work going longer. If he could get 2000 hours would very happy.
Also looking at try try get sone off the people run runing crushers to give them a go.
Got 2 cilnets will to give them ago now.
Other one is how do you sell them, price per stud all in or consumable and hourly rate.
Which is the better qualitly?
Any feed back what so ever would be great.
Dave
RayF
Perth Western australia
lineborer/welder
Studs were all the go here in mining trucks and heavy buckets about ten years ago. Never see the any more. I think wear plate has improved so much its made the studs obsolete.
If you are considering studs for dozer corner shoes I'd say you are wasting your time. In that application my preference would be for a spray-on protective edging something like Cat's ARM material, although that's not by any means the only product around. The material needs to be applied before the part is installed so that it can work-harden during operation.
Crushers - no idea.
