I have been doing some research on this forum and there is some mention of compression testing of diesel engines ... but no procedures that I could find.
YouTube research has resulted in a bit more information ... but as YouTube does, the procedures vary by the presenter.
I plan to use the following procedure:
1) Warm engine up
2) Disconnect electrical connection to fuel shutoff solenoid on the fuel injection pump
3) Loosen off the high-pressure fuel line connection to each fuel injector
4) Remove glow plug from cylinder to be tested
5) Insert adapter into glow plug port and connect pressure gauge
6) Engage starter for 5 seconds or longer to get a stable pressure reading
7) Reinstalled glow plug
8) Repeat steps 4 thru 7 for the other cylinders
The one thing that I have not confirmed is what compression test pressure will be acceptable … from what I have read, acceptable is somewhere in the 400 psi range and each cylinder should be within 10% of each other. But this is just word of mouth … with no confirmed source at this time.
Does anyone have any suggestions on the above procedure? Anything missed or wrong?
I am a bit concerned that “a compression test is not part of Cat’s testing procedure” (thank you Nige) … I wonder why that is … and I hope I don’t find out why either by doing a compression test
