Trailer rebuild/repair thread
Discussion in 'Trailers' started by RZucker, Feb 16, 2019.
  1. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Made some progress on the current project. Got the boxes built and mounted up. 20190218_105135.jpg 20190218_142822.jpg
    DMiller, Truck Shop, walkerv and 3 others like this.
  2. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    I love it !
    Excellent work RZ .:cool:
    DMiller and RZucker like this.
  3. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Thanks td, but this is just "Get 'er done" not artwork. Got a couple things a bit out of square (not that it can be seen) and a run in the paint. :D This trailer will be back in late May or June for a real rebuild with a blast and paint all over. I'll be cutting off unused strap hooks and other junk first. Oh, for Miller... this is an early 70's Utility too.
    DMiller and td25c like this.
  4. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Also moved the side marker/turn signal up the side rail and boxing in the rear side to seal them up. Made a plasma cutter jig that makes it easy peasy. Have several cutting jigs for different light holes. 20190215_075434.jpg
  5. DARO
    DARO Well-Known Member
    Sep 8, 2014
    178
    Mechanic
    Duluth MN USA
    @RZucker do you have a pic of your jig for light holes? They look very well done.
    DMiller likes this.
  6. DARO
    Sep 8, 2014
    178
    Mechanic
    Duluth MN USA
    Oops i didnt realize that was the jig. :(
    DMiller likes this.
  7. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    No problem, I make them myself. My plasma cutter has a drag tip with a 3/16" center. I use 3/16" plate and make the hole in the jig 3/16" bigger than the hole I'm cutting. The oval jig above I use a self drilling/tapping screw to hold it in place while I cut, a quick zap with the wirefeed hides the screw hole. If I have a clamp that will reach I don't need the screw.
    DMiller and DARO like this.
  8. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Another one from last year. Obsolete suspension that need new equalizers. Had to have a new channel formed from 1/2" steel to mount it all up. 20181107_134621.jpg
    DMiller, hvy 1ton, JPV and 2 others like this.
  9. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Not exactly a trailer, but this is next weeks welding project. Some buildups, crack repairs and other miscellaneous work. Plus it has two friends that will be in soon, too. 20190227_124238.jpg
  10. petepilot
    petepilot Senior Member
    Jul 7, 2018
    947
    central shenandoah valley va,
    baler of some sort ?
    DMiller likes this.
  11. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Yep. New Holland 340. 3x4 x8 foot bales. They get a lot of abrasion wear inside.
    DMiller likes this.
  12. petepilot
    Jul 7, 2018
    947
    judging from the shiny rollers it has`nt been sitting idle
    DMiller likes this.
  13. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    It was last used in September of last year. the owner keeps them stored inside.
  14. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
    Hi RZucker! It’s my first time on this thread. That hay pup looks familiar, is that Busby?
    DMiller likes this.
  15. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Equipment under roof is money in the bank .
    DMiller, old-iron-habit and RZucker like this.
  16. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    No, I built the entire trailer from scratch on a set of 1944 Utility frame rails, added 4 feet of I beam to make it a 24 foot pup. Busby did bend the rear sill for me though. I guess I have seen enough of their stuff to have an influence. Mike and his guys do a great job making custom parts for me.
    DMiller likes this.
  17. TVA
    TVA Senior Member
    May 14, 2018
    1,731
    USA
    My first super chassis was Busby! That’s why that tall and skinny I beam looking rear sill reminded me of them.
    DMiller likes this.
  18. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    If I ever get down by their shed, I'll get a pic. It's a huge Quonset type tarp building 300 plus feet long and 75 feet or so wide.
    DMiller, petepilot and td25c like this.
  19. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    There's a lot of their can chassis around here, but I think they are only building the "Bomb Carts" now, those are the Container chassis for the docks that don't need to be licensed. Dang heavy trailers that can handle overloads and abuse you wouldn't believe.
    DMiller likes this.
  20. RZucker
    Jul 7, 2013
    4,022
    Mechanic/welder
    Wherever I end up
    Not a trailer, but close. Big box scraper had a wheel break off. Beast is 19 feet wide. 20190304_131447.jpg 20190304_140443.jpg 20190304_140809.jpg
