Blade_Runner
G'day! I'm new to the forum (been reading for a few days) and new to grader driving, having just done my first week on a grader.... so I have all of about 30 hrs of actual grader driving experience!
My job involves maintaining about 2000km of gravel roads within our shire (council, county) in Western Australia. I drive a Deere 670D (~8800 hrs) with rear mounted ripper and roller attachments.
I have been instructed to drive in 2nd or 3rd gear while grading and (max) 4th gear while rolling/compacting only.... and spend most of my time cruising along at about 1900 rpm in 3rd (grading).
I was reading a John Deere brosure (https://www.deere.com/en_US/docs/construction/non_current_products/motorgraders/DKADGDRTD.pdf ) and noticed the 670D puts out more torque/HP in 4th gear, than it does in 1 - 3rd gears.... (611 ft/lbs vs 554lb.-ft max @ 1000 rpm). This got me thinking.....
Because a grader is all about moving dirt efficiently (not quickly), would it make more sense to sit say on 1000 rpm in 4th, rather than 1800 rpm in 3rd, or whatever the equivalent speed would be, given that the engine is producing more net torque at 1000rpm in 4th? Or is the lower rpm going to be harder on the engine in the long term?
Obviously, the lower RPM range is quieter, with less vibration (important when doing 10 hr shifts)
What rev ranges do you guys use on long runs?
