2500-3000ft lbs on a 1" bar....? I think I'd be looking at 1-1/2" drive TBH, just to be on the safe side.
Or you could try something like this, and believe it or not I took this photo yesterday afternoon. The cylinder bench wasn't capable of getting this nut cracked. 5,000 ft. lbs. give or take and the last time it was tightened was before it left the factory so it was going to need even more than the specified torque to initially crack it. So we came up with this which is a solution I'd used years ago in places where there was no proper tooling. A 4ft-long wrench plasma cut from 1-1/2" plate (it weighs 300 pounds on its own, that's why it has a lifting eye on it) anchor the eye end of the rod down with the loader bucket so it can't turn, excavator bucket on the end of the wrench and give it a gentle squeeze - job done in less than 60 seconds. To tighten it we simply marked the relative positions of the nut and the rod before disassembly and will tighten the nut back to exactly the same position because we are not replacing any hard parts, just resealing. If we're going to have these machines for at least 10 years or so the expense of manufacturing the wrench will pay for itself many times over. Just to give an idea of scale the loader is a 980 and the nut is 260mm (10" give or take) across the flats. We used a 336 excavator as the muscle.
