Torque converter???
Brandt
Wyoming
I have a Case W20B with an Allison TT2221-1 trans. It has always struggled to get up my driveway (about 15% grade), and I just would deal with it. Now it refuses to dig going up a very small incline, and it can't make it up my driveway. While roading it: going up a grade it slowed way down, but the engine rpm's remained high. Going down a grade, it sped up, but again the engine rpms did not change. Is the torque converter bad??
The parts and Op manual says that this machine should have a 4 speed trans in it. It only has a 2 speed. I'm guessing it was swapped out before I got the machine. If the trans has to come out to get at the TC, should I look for a 4 speed to put in it?? If so, what model #.
The failure mode for bad torque converters is to continually run hot or to put copious amounts of aluminum filings into the transmission oil. Sounds to me like you have more than one problem in the drive train.
Tinkerer
Brandt
Wyoming
OK, I need to start at ground zero. I don't have a temp gauge on the trans and didn't see any bits of metal last PM.
I need to find somebody that knows how this is suppose to work and take it to them. I have played with the linkage in the past and got no change. Lots of John Deere mechanics around, but not too many Case guys. This is when living rural sucks, I may have to take the machine 200 miles or so.
john hofer
alberta, canada
I agree. I believe it's the torque converter bearing. It's not a terribly hard job, but there are a few other items to check out while you're tearing it apart.
We help people out with these a lot. Give us a call and we can fix you up with the parts you need to fix it up. (800) 552-5080
I have pretty much the same trans haven't looked at it yet,maybe call these guys
Do you have an operators manual for this thing? how about a repair manual? I'd be sure the fluid level was correct, and that you're getting it in the proper gears, and then call whichever Deere mechanic you think has the most experience, it's not that different that I'd haul it 200 MILES to get to a Case mechanic who might not remember these systems anyway.
kith
iowa
You need to check your shift linkage. They get pretty hard to find all the gears,also have pull up on shift lever to get to the higher gears.
john hofer
alberta, canada
If it has the same shifting lever as a tt2422-1!
How does it work in verse ?
Torque converter pressure 250lbs plus?
I think you are in high gear
Disconnect the shifting linking at the transmission, use a pliers to move the shifting pin,it should lock into position at 4 points,all the way in is verse, next one out is neutral, third is low gear,fourth is high.
Coy Lancaster
Arkansas
service tech
Hey Brandt I know this is kind of a late post on this but did you figure out anything on you W20B? When shifting for road gears lift up on shift lever to go past stop for third and fourth gears. Be sure you are using correct fluid in tranny and it is at right operating level.
Brandt
Wyoming
I haven't done much with this machine as my 955H has a bad turbo and is getting all the attention.
I have played with the linkage in the past - to no avail. I have an old school mechanic going to look at it sometime in July.
Tinkerer - Thanx for those last pix and link. That might help out.
Coy Lancaster
Arkansas
service tech
Like I said when you move the shift lever to the stop just pick up on it and move it again.
Brandt
Wyoming
It still doesn't explain why the engine rpm stays high and no power is getting to the wheels
DMC
QC
Stupid question, but have you checked the transmission level while idling. My old MF-70 did the same thing,,oil was too low.
