I also recall an incident with the installation of the swing bearing on a Cat 390 using a hytorc. Someone got the translation between Kpa and psi mixed up. When the first one let go it left a nice impression of a bolt head in the top of the carbody.
Same thing assembling these machines I'm working on right now. I posted some pics of cleaning out the holes. Last truck the boys forgot to run a tap through the threaded holes in the diff housing with the result that 2 out of 20 of the 1-1/4" bolts didn't want to run all the way in. Fortunately the rattle gun got them out but they looked a bit 2nd hand. I put them up on the "Employee of the Week" board in their crib room just to remind them why we run taps through all the big critical threads before going near them with hardware. I don't know which one of them did it but I'm sure they know and they're ripping the pi$$ out of him............The sad fact is many engines assembled even after a visit for machine work the thread bores are never checked. Standard thinking is it's all clean and just needs to be blown out.
Most cleaning tanks/washers don't really clean those areas, any metal removed from machining because of it's irregular shape can wedge in threads and won't come out with just a blow
gun. It's just something I learned doing automotive machine work-it never fails the crap stuck in flutes of a tap used on a fresh machined and washed cylinder block.
That's not bad. It's only a factor of 7 in round numbers.........I also recall an incident with the installation of the swing bearing on a Cat 390 using a hytorc. Someone got the translation between Kpa and psi mixed up. When the first one let go it left a nice impression of a bolt head in the top of the carbody.
I swear I have seen more damage from idiots with a tap in their hand!
