My math is rusty...
F=ma
tree mass for a number is 2000Kg's
Acceleration 9.8m/sec/square
F=192080 newtons of energy
which is 43181 lbs of energy ..if it free fell for one second ...I dont have the constants for air resistance ...
It really dosent have to get big to get heavy ...in a hurry ..
True. My opinion about what happened:
I'm an arborist. I've been practicing for 35 years. done a fair bit of crane assisted work. Some good posts here, but some not so, even a few that sound like they've come from crane operators.
It's obvious, to anyone who looked at all 24 photos up on the newspaper website, that the tree crew had some degree of competence. This was a huge spreading tree.
However, some questions and possible explanations as to why
One, why was the jib installed? Greatly reduces the load chart. Certainly it would have been better to have had the boom fully extended (It isn't) than to have the jib on.
Two, why weren't the full complement of counterweights installed? In one of the photos, it looks like there's more on the flatbed. If so, they appear to be doing a good job of holding it down. Possible reason--the tree company is paying for the crane with its lower rating, to save money.
Assuming this is a Grove 5175, with the amount of counterweights installed, the load chart shows its good for about 6200 lb. not exact, as the boom isn't fully extended, but the jib is on.
That means trouble....as I've estimated the log that caused the failure to weigh between 5000 and 8000 lb.
Which brings us to the next problem, and that is how the climber made the cut. If one looks at the log in the street, and the way it appears in the tree, one can see what the top of it is showing, which is how the climber made the cut that was just above it. He made a mismatch cut, but on the bottom side instead of the top (the side away from the crane, and perhaps away from its lean. This is a guess, as it may have leaned away from the crane, in which case the cut may have been correct.
Anyhow, my point is, with sections that aren't vertical, they should be picked toward vertical, gently, till the center of balance is directly under the slings. Then, the section can be gingerly picked off, reducing shock loading to a minimum. Best ways to do this, when there's concern about the weight being close to the max is either peel the log, with one cut, starting from the side the weight is on. Alternatively, a face cut can be made on the opposite side.
(There's a different method for lateral picks, which involves two slings to balance the load, and picking it horizontally.)
Continuing, the log on the ground out front is the last pick made before the collapse. It is larger diameter, but straight, and was closer to the operator. Therefore, on the failed pick, the boom was at a lower angle, and further away. And the load wasn't vertical. So, it should have been cut as I described, and slowly lboomed up to vertical, which would have brought the boom and load closer to the centerpin, thus increasing lift capabilities.
Since the reports state there was shock loading, I think the cutter made those same improper mismatch cuts, and the full weight came onto the cable as the butt fell off. In an instant, the dynamic forces on the system would have spiked up. Just a guess, but assume the piece was 20 degrees off vertical. If the heavier butt fell off, and it fell/swung two-four feet, the dynamic loading could have easily doubled--or worse. This force is hard to figure, but know this: A free falling 5000 lb object onto a fixed cable will apply 10,000 lb to the system after falling 1 foot, and 15,000 after two feet!
Mistakes, as I see them:
Improper cut
Jib on
Not enough counterweights.
Crane operator may have had too little tension on the load.(I'm guessing this is wrong, as they'd already done 95% of the tree, without incident, and he should've had a good feel for the weights.)
