TL130 feul selenoid
miltime
cape Cod
The fuel solenoid on myTL130 will pull in but will not hold, I have pulled the solenoid out and put 12 volts to the black and white wire and it will hold but gets hot quickly, I have replaced the emergency relay and the stop solenoid relay and the stop solenoid timer relay and still does not hold, I put a multimeter to the plug for the solenoid black and white shows 0.12 volts then turn the key and get 12.2 for a second then holds 0.11 volts, test the black and red wires and no voltage till I turn the key and get 0.04 volts, Any suggestions?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Its possible the HOLD coil in the sol. is burnt up.. happens a lot..
The BLACK & WHITE is the PULL coil & is only momentarily supplies w/ 12V & lots of amps usually from the starter..
The BLACK & RED wires are the HOLD coils{black being -} & usually get its power from 1 of the relays.
The easiest way I found to test 1 is> TAKE IT OFF.. & w/ a jump box or battery charger.. 12v low amps & testing the cols 1 at a time.. When testing the HOLD coils, u HAVE TO PUSH the plunger IN & see if it will hold..
Not as much pressure is needed on the PULL coil but some will be required.
miltime
cape Cod
I have replaced all the relays , stop relay and timer relay , emergency relay and was told volt comes from instrument cluster and have also replaced that , now I get the proper 12v kick from the pull relay but am only getting 4volts to the hold circiut, feul solenoid is new also
thepumpguysc
Did ur new sol. come w/ a mounting bracket that has elongated slots.??
&/OR.. Does it have a "rod" adjustment?? {2 lock nuts}
The hold circuit drops off because it doesn't require very many AMPS to hold it..
U need to adjust it..
The plunger MUST BE BOTTOMED in the housing when its FULLY retracted..
UNHOOK IT from the lever.. & activate it,,get it bottomed in the housing..
Now WITH IT RETRACTED IN THE HSG.. MANUALLY pull the stop LEVER..
The connection/holes MUST line up..between the LEVER & the SOLENOID ARM..
Good luck
It shoulda came w/ instructions.??
