The fuel solenoid on myTL130 will pull in but will not hold, I have pulled the solenoid out and put 12 volts to the black and white wire and it will hold but gets hot quickly, I have replaced the emergency relay and the stop solenoid relay and the stop solenoid timer relay and still does not hold, I put a multimeter to the plug for the solenoid black and white shows 0.12 volts then turn the key and get 12.2 for a second then holds 0.11 volts, test the black and red wires and no voltage till I turn the key and get 0.04 volts, Any suggestions?
