Yea I suppose it's possible. Extend releive valve is set at 2000 psi right now. Maybe i could back it off to prevent damage.It looks like you could extend the hoe to retract the thumb if you were careful not to go too far.
I would say in my case it's a bit of a pain to use for just one rock or stump because the extradig has to be in just the right spot for the pin holes to line up. Wouldn't be an issue on a one piece dipper tho. As far as function tho it works great and it's not in the way when stowed.It looks like you got it all figured out
Are you in love with it or is it just ok?
Sounds like you have a solid plan, the couple I put on are still working great and like you, an excavator with a hydraulic thumb is much nicer!Thought I would cap this thread off with the eventual demise of this install. After 8 hard years of use it finally failed and ripped open the crowd arm at the welds. Not a catastrophic fail but a fail nonetheless.
