Titan weld on thumb install.
Tinkerer
usa
My new thumb was broken the first time I used it Saturday. :mad: I didn't abuse it , just moving cut up logs to a burning pile. I never run the backhoe with the engine throttle above idle speed. It has adequate hydraulic power at that speed to do about anything I want it to do. Which includes raising and swinging a full bucket of dirt at the same time.
The photos will show a weakness in the mounting plate. I repaired it and eliminated any future problems with a piece of 1/2 inch wall 1 inch ID pipe that I purchased online.
The first image shows the elongated pin hole on the RH side and the broken one with a piece missing on the LH side.
Image 2 is the repair. I painted it yellow to make it easier to see.
Image 3 is the heavy wall pipe I used to strengthen the mount.
I replaced the soft and distorted pin that the thumb mfr. supplied with a 1 inch x 8 inch grade 8 bolt.
Hoprfully my sad experince wil help someone else that has the same problem.
xgiovannix12
New York
Operator/Mechanic/Truck driver
that sucks man Mines holding up great on the 580c I used it the other night feeding a fire
joe--h
Utah
I'm looking at pic # 2 and seeing a mount bracket that looks to be much thinner than what I have. Mine is the same thickness as the thumb, yours looks like its half that thickness?
You might send a picture to Titan & see what they think.
Joe H
showrguy
Marysville, Pa.
Joe H
I just got one delivered about a week ago..
The weld on bracket is 3/8, the toothed thumb is 5/8..
Damm, that thing is heavy..
Tinkerer
usa
Joe H
The mounting bracket welded to the backhoe boom is a measly 5/16 thick plate.
That is totally inadequate when you consider the small amount of steel on the outer diameter of the eye for that bottom pin.
Just think about how much pressure is generated not only by the hydraulic force, but the additional pressure of a log 24" x 10 feet long all of it pushing against that area.
It may have enough strength for a Case 580 size T/L/B but certainly not a 680 .
showrguy ; Who is the manufacturer of your thumb ? I am curious if it the same as mine.
showrguy
Marysville, Pa.
I got mine from Titan directly..
joe--h
Utah
I got it from Titan also. Made in China, no marking at all on it.
And you're right, the bracket is about 3/8". Had a look at it yesterday and I was wrong. First time ever.
Joe H
Tinkerer
usa
Mine is a Titan also. Bought it on eBay. I sent those images of the damage only, to them this morning.
I hope, but I doubt if I get a response from them.
xgiovannix12
New York
the bracket on mine is pretty thick thicker then 5/16s at least
NH575E
North, FL
Retired Machinist
Tinkerer which model/size did you buy?
Mine is also holding up great. Was pulling small stumps out with it today and thinking what a great tool it has been. Dug and picked up several larger stumps but the small ones I clamped onto and pulled with the thumb and bucket.
ovrszd
Missouri
Retired Army
My pet peeve is the pin latching system. I have lost all the pin clips. I'm actually running large nails inserted and bent around the pin to reduce the chance of snagging. Not handy at all when wanting to change the position of the thumb. The pins are so short you can't even install a bolt with locknut...…. :(
Tinkerer
usa
It is a 32 inch. I followed the measuring instructions that are on the internet in regards to fitment.
It is not too small for the bucket I use with it.
You can see the grade 8 bolt in the new bushing I installed
showrguy
Marysville, Pa.
Where did you find instructions for fitment ??
I looked everywhere to no avail, figured we could figure it out with a little common sense ..
Tinkerer
usa
A Google search for "how to measure a backhoe for a thumb" will bring up a few websites that have pictures and instructions.
But, when I was looking on ebay for a thumb, there is a brand named Linville listed along with Titan.
Any of Linville's listings will have a picture and instructions about measuring for the correct size.
It is quite simple. Position the front of the bucket at a 90 degree angle to the dipper. Measure from the inside face of the dipper to the end of the bucket teeth. That is the size thumb you need.
I wasn't exactly at 90 degrees in the image I posted. I had just finished welding the new reinforcing bushing in and it was hotter than h** outside. That is why the connecting link is not mounted when I snapped that photo.
NH575E
North, FL
Retired Machinist
I replaced the supplied hitch pins with cotter pins except the one I remove to stow it. I drilled the hole in that one to the next size hitch pin and haven't lost one since.
showrguy
Marysville, Pa.
Oh, I already have the 36" thumb, I was smart enough to figure out what size I needed..
My quest is for the position of the weld on bracket location info...
NH575E
North, FL
Retired Machinist
That was my reason for starting and updating this thread. The method and position I used on my 36" has worked perfectly for me.
Tinkerer
usa
NH575E shows his located in the correct position earlier in this thread.
A professional welder has a YouTube video showing all you need to know about doing it correctly. The video quality is poor the advice is excellent !
Tinkerer
usa
I'm reviving this old thread because I had another design flaw rear its ugly head a couple of weeks ago. Maybe someone will benefit from my problem ! I am posting a photo of the pin that bent in the thumb link and had to be cut off. The link is tooo narrow for the thumb and allowed the damage to occur. I still had enough of the heavy wall pipe to make two bushings to hopefully eliminate any more pin bending. I bought another grade 8 bolt to replace the bent pin.
