7 loads from a 953 to load a tandem truck? They must have been pretty overloaded unless it was topsoil. I can overload a tandem of moist clay in 7 buckets with a 931B. The hoe on back helps super heap the bucket.
Yep probably grossing 75k. Typically 5 if on road. 6 if you can't get it heaped7 loads from a 953 to load a tandem truck? They must have been pretty overloaded unless it was topsoil. I can overload a tandem of moist clay in 7 buckets with a 931B. The hoe on back helps super heap the bucket.
Bingo! Which is why I am sort of torn. Basically just trying not to waste money if I have problems and I have time to think on this project. I know I spent months on a PGA golf coarse project where we were running a 966 around. Was amazed how that ground felt so solid, yet that 966 sunk many inches. Later in engineering, I learned that soil is a spring but the "pumping" thing is largely a civil side in understanding. Basically compression of the soil squeezes any water out and can cause an otherwise stable area work well for a few cycles, but eventually go to hell. Each pass does not firm it, but makes it worse.The weight of the loaded hauler might start pumping the ground like driving on a sponge and it will be impossible to keep it level. When the gravel pit brought over a 180 Volvo loader it made the ground seem like a sponge where with any of my machines it seemed really firm and solid.
^^^^^^^This.At some point you need to pick the option you think is the most viable and try it. I’d start with something that doesn’t cost much out of pocket and get to work. I often take a little note pad and a stopwatch and get e real data on how things are going to work out such as cycle times, actual volumes in trucks, bank vs loose yardage etc. After a day or so, sometimes even a few hours, you have some real numbers you can use to figure out how to proceed.
