Tightening tracks on a D5M
Rickyb1968
Arkansas
Ok i have gotten around to counting the pads and i have 44 on both sides. Do they make a special wrench to get to the top bolt? Cant get a socket on it and a wrench is to big to turn inside. Its a 22mm. Manual states to loosen top bolt one full turn to let grease out and then tighten back up and add grease to get correct track sag.
That confirms the tracks haven’t been shortened by removing a link which is often the case on older machines as an alternative to replacing the complete link assembly.
An open-end wrench should loosen it. It shouldn’t be that tight.
Nige, that bolt should turn counter clockwise to loosen correct?
That's correct. It's actually a bolt with a conical end on it that screws into a mating seat in the block. The specified torque is only 26 ft lbs.
Not a very good illustration but it gives you the idea. That's the two fittings on the adjuster.
