Tight hydraulic fittings
Discussion in 'General Industry Questions' started by Welder Dave, Jun 25, 2022.
  1. Welder Dave
    Welder Dave Senior Member
    7,387
    Can hyd. hose fittings become super tight over time? I had to remove the 6 hoses from my backhoe valve that go down the boom and they all needed a snipe to get loose. One almost didn't come loose and started to distort the nut. I've had the hoses off before and put them on snug using the proper size wrench but certainly didn't reef them as tight as possible. What would cause them to be so tight to remove?
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    4,534
    Mechanic
    Will county Illinois
    BSPP and German metric will both flare the tip of the fitting if over torqued. JIC and ORFS usually won't get messed up except for rust.
    Vetech63 likes this.
  3. willie59
    willie59 Administrator
    Dec 21, 2008
    12,831
    Service Manager
    Knoxville TN
    If the fitting is out in the open a hammer is your best friend, and I $hit you not. Any fitting, smart whacks of the flats of the fitting nuts, the more flats you can access the better. I'm not talking about beating the hell out of it, just smart whacks on the flats. Does two things, 1) slightly expands the metal of the nut from compressive hammer blows, and 2) disturbs the thread connections, sort of like the difference between a wrench on a nut opposed to an impact gun. Some smart whacks on a fitting nut and I promise you it will come loose with ease.
  4. Welder Dave
    7,387
    Really hard to smack on a backhoe valve with multiple connections in close quarters and upper and lower fittings. Had to remove the top hoses to be able to get a wrench on the bottom ones. I got them loose but boy they were tight. Never heard of using anti-sieze on JIC hyd. fittings but maybe just a touch would be a good idea?
  5. JLarson
    JLarson Senior Member
    Aug 23, 2020
    566
    AZ
    Air hammer and a long punch or chisel.
  6. Welder Dave
    7,387
    Sounds like like others have had the same problem.
  7. willie59
    Dec 21, 2008
    12,831
    Service Manager
    Knoxville TN
    Hammer and a long punch or chisel. I've done it on tight quarter fittings on valve bodies. I'm telling you it works.
  8. Welder Dave
    7,387
    I'll have to try that next time.
  9. 1693TA
    1693TA Senior Member
    Feb 27, 2010
    1,139
    FAA Radar Engineer, (Retired)
    Farmington IL
    I have warmed them no hotter than you would do with a propane torch and they have come loose. A second person running an air hammer while you turn a wrench works well also.
    John Shipp, Vetech63 and BigWrench55 like this.
  10. Welder Dave
    7,387
    I considered warming them up with a hand held propane torch.
  11. 1693TA
    Feb 27, 2010
    1,139
    Farmington IL
    The drawback to using propane is it is slow to warm the metal so both the female, and male threads tend to expand together gaining little. Acetylene, or another fuel gas heats quicker expanding the female threads faster than the male threads making loosening the fitting easier.
    I am assuming you have female threads on your hose ends.
    DB2 and Vetech63 like this.
  12. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,899
    Excluding rust, one thing. Overtightening. There's only one thing that boils my p!ss more than a hose fitting that has been reefed on so much that the nipple comes loose when you try to undo it. The recommended torque for a 1/2" JIC fitting is only 40 lb ft. Go easy people.
    DB2, Vetech63, Welder Dave and 2 others like this.
  13. terex herder
    terex herder Senior Member
    Nov 10, 2017
    1,006
    Kansas
    I agree with the proper torque comment, but some of the china adapters have to have the hose tightened way past proper to get the drips to stop.
    Vetech63, Spud_Monkey and shopguy like this.
  14. 1693TA
    Feb 27, 2010
    1,139
    Farmington IL
    And fittings that have been reused a time or two tend to leak if not overtightened......
    Vetech63 and Welder Dave like this.
  15. shopguy
    shopguy Senior Member
    Jul 2, 2011
    467
    if you Use a open end wrench make sure that it fits the flats really tight or it will ride up the humps and squeeze the nut,I found this out the hard way trying to get by with I had with me at the moment
    DB2, Vetech63 and skyking1 like this.
  16. Welder Dave
    7,387
    I probably had them a little tighter than 40 ft./lbs. but certainly didn't use a snipe on the wrench like I had to to get them loose. I'll make sure to put them just snug when I put them back on. I also think fittings that have been reused need to be a little tighter to stop any leaks.
  17. funwithfuel
    Mar 7, 2017
    4,534
    Mechanic
    I wouldn't go light on reassembly, not with JIC. The flares and tapered seat are designed to be "tightened up " As soon as you put it to work and get a little vibration, you'll have a leak.
    muddog1975 and Vetech63 like this.
  18. Welder Dave
    7,387
    I'm wondering if there is something that could cause the fittings to become tighter, whether it's temperature changes or just over time they become tighter.
  19. funwithfuel
    Mar 7, 2017
    4,534
    Mechanic
    Like i mentioned earlier, a little corrosion can make things difficult. Aside from that, if the last guy pulled crazy torque and deformed the threads a bit, that'll make things rough.
    Now someone mentioned striking the flat with a hammer and punch. I've done that, it has both helped and hurt. I buy the right wrenches cuz, well, I'm a dealer tech and people tend to frown on seeing gouges and dings.
    muddog1975, Vetech63 and Spud_Monkey like this.
  20. mekanik
    mekanik Senior Member
    Aug 20, 2015
    507
    Canada's Northwest
