It's been a long time since I've been around a 40F, but seems I recall the steering bypass valve between engine and the frame that boom is mounted on, has a black push/pull knob on it. But since cylinder is already disconnected and you need to roll, you could get in the platform, operate the steering, and retract the steer cylinder out of the way to accomplish mission.
As for towing, 20 miles is way pushing what JLG designed towing for. Not saying it can't be done, I don't know. What I can tell you is yes...low speed towing only. The reason being is that the disconnect only disconnects the planetary drive hub from the drive motor/brake unit. But when you're towing is this state, the gears/carriers in the planetary hub are still rotating, and they're not designed for high speed operation. Tow too fast and you can damage or grenade the planetary hub.
One option would be drain oil from planetary hubs, remove hub cover, and remove the planet gear carrier. Re-install hub cover and fill with oil. If you do this you would only be rotating the bearings in the hub, no danger doing that. Of course, can't address how the machine would react to higher tow speed as I have never gone there.
