Hi all OD1 here, I'm back with another in a long line of 40F Dilemmas
Well I’m back, it’s been a while. I’m OD1 the founder of this blog. I’m still working on my 40F which has developed a new dilemma.
I’ve made some improvements to the throttle and choke and placed 2 new filters at the 40F rear to hopefully relieve the inherent problems with the Bertea valve body, and at the same time added one for the Bang-bang side.
So I finally got the hoses installed thanks to “OFF” who has been there for me through this interior mess.
Okay so I had to pump out the tank to install the new lines and at that time I removed both valve bodies and did a partial rebuild, and added 2 new springs to the Bang-bang valve body. Cleaned everything up and reinstalled. Refilled the reservoir, primed the fuel pump and started the engine which was sitting for a few years now. Kicked right over. Had to deal with a hydraulic leak but that was fixable.
Here’s where it goes bad. No functions, I’m running everything from the ground control. I cut all the lines to the platform and only have ground control. Okay so I thought I’d let it warm up a bit.
So while it’s warming up (I was a little bored) I threw the switch from ground to platform. The engine dies, which is normal, and then I threw it back to ground and it’s running again. Maybe 30 sec. later I do it again. Same response engine stops and then starts. Then it just dies.
I hit the starter button, nothing, choke button nothing. I check the breakers all look good. I didn’t have a multimeter with me. I thought maybe the switch throwing was just a coincidence, maybe the alternator wasn’t functioning and the battery was just dead. I went and got a 4 amp charger and connected it up to the battery while still connected to the 40F, (I’ve done this before) and the charger shorted out.
In the past when you turned the key you’d hear a click, now nothing. The switch that functions the ground to platform seems physically to be in great shape although I did not test it for continuity.
This is what I did so far,
I disconnected the battery, and cut out 2 diodes that I found in the main panel that seemed to go with the ground box. Remember the other box (platform) has been removed and the wires have been pulled out. Did a diode check and they’re like new. I did see 2 or maybe 3 others way up in there but I’m not sure if this is a diode issue.
I’m dead in the water. And I don’t know what else to look for. I’m hoping someone else has gone through this and can point me in the right direction.
Thanks so much for taking the time to read this through. I'm so happy to see that this site is helping so many.
Regards, OD1
:Banghead
