TEREX TL100 - LOSS OF AUX. HYDRAULICS
TEX32
Sault Ste Marie, ONT, Canada
Owner, Technician @ INTEGRITY HEAVY REPAIR INC.
Hey guys.... As the header says.
Our Terex TL100 loader has lost its aux hyd function.
The control switch in dash is a momentary switch that turns on or off the circuit. ( Momentary tap one way, aux function ON. Momentary tap other direction, aux function OFF )
Switch swapped out with FLOAT switch ( to verify good or bad switch ) Still no aux oil flow ( from tilt cylinder to aux hoses )
All fuses good.
Do any of you happen to have a wiring diagram for this unit?
Tex
TEX32
Hi, Did you solve this ?
Well yes. Sort of... I ended up hardwiring into the auxiliary control valves and running a new switch. Temporary until I can get her in, to repair properly. I found it was faulty trigger buttons in the joystick.
jusuplus
finland
i have bobcat al440 and i have a similiar problem. Cannot turn aux hydraulics on and nothing happens on joystick buttons
