Terex Parts
Discussion in 'Scrapers' started by Indyhoosier, May 30, 2014.
  1. John Wayne
    John Wayne New Member
    Feb 7, 2018
    3
    Saratoga, Wyoming
    Thanks for the quick reply!
    The machine is a 2006 with 5.9 Cummins tier 2 in front and back. Mechanic has removed the hydraulic pump stack, transmission pump from machine and started it without parasitic loads and it still “chugs” and vibrates then takes off. I believe the idle is at 700 rpm. Cummins came out and adjusted the idle and checked out the engine however still “chugs”. Machine has a new coupler and rebuilt drive. Maybe 1/16” free play in the driveshaft before engine turns. When it “chugs” excessive rattling noise from rear drive can be heard as well as during engine shut down. Not sure if/when transmissions have been calibrated. I know they shift because we recently had to replace voltage protection module for power to ecu’s. Engine runs good however does its “chugging” when first started in the morning. It does not matter if it is 20-80 degrees Fahrenheit. Engine will “chug” and eventually break the driveline. “Chug” condition can be duplicated if the machine is idling and the hydraulics are actuated. Transmission was recently resealed by John Deere dealer and they said everything looked good inside. Problem existed before jd resealed transmission. We are not sure which way to go without throwing expensive parts at it. Any ideas would be greatly appreciated. Did Terex update/replace that entire drive to eliminate that noise?
    Thanks
  2. GaryHoff
    GaryHoff Senior Member
    Feb 26, 2009
    750
    Heavey Equipment Mechanic
    Alberta, Canada
    I would recommend adjusting your low idle to at least 950rpm. Higher low idle RPM will help with the chugging. You can set the low idle with the idle switches.
    Check that your ECM software was updated by Cummins. There should be a newer dataset available (if it wasn't done yet)
    The doldrums issue was never properly resolved in my opinion, just reduced the amount drive shafts and couplers broke. I usually
    see the driveline break just after coffee time when the operator starts the machine back up.
    Excessive rattling at start up and shut down at the rear engine is usually the drive coupler on its way to breaking.
    You can calibrate your transmission by following the instructions below. The plugs are in the fuse box area, they are the weather pack connectors.
  3. John Wayne
    Feb 7, 2018
    3
    Saratoga, Wyoming
    Thank you Gary! We will try the calibration and make sure Cummins installed new software. We have tried adjusting the idle off the switches but it still rattles. Does anyone that you know of build a different drive group for the front engine and hydraulic pumps?
    Thanks
  4. GaryHoff
    Feb 26, 2009
    750
    Alberta, Canada
    The rattle should get noticeably less at the higher idle rpm.
    You could also try installing a non-terex engine calibration. I haven't personally done this, but a truck application or similar calibration may work.
    I don't know of anyone building a different drive group for the front engine that would directly fit on this application.
  5. Questionable wizard
    Questionable wizard Well-Known Member
    Feb 10, 2018
    71
    Ohio
    So the rattle is in the coupler/driveshaft?
    I am new to the Terex G's. Have a 2002 model with the DT466's. The front driveline rattles loudly at idle. 64XX hours. Front idle is at 750 rpm. Machine has lots of high heat/neglect issues. Should we be inspecting as a preventative measure?
  6. GaryHoff
    Feb 26, 2009
    750
    Alberta, Canada
    They all seem to rattle to a certain extent. The Detroit engines didn't seem to have as many driveline issues as the Cummins did. Parts are getting rather difficult to get, so knowing what you need before it completely fails is always good. The front engine couplers aren't as prone to failure, but your splines on the yolk may be worn out. Any recent drivetrain issues.
  7. Questionable wizard
    Feb 10, 2018
    71
    Ohio
    No drivetrain issues. We've have this machine for three years. It came from the Richie Bros problems disposal auction with a fresh coat of paint(first warning). I've been fighting issues with the rear engine TPS, IVS, and BPS among other things. So it hasn't gotten very many hours. The rear engine codes for those sensors is intermittent. As soon as the engine is shut down and restarted, the problem goes away for 5 minutes-1/2 day. Can't replicate what causes the codes. Replaced those sensors and the engine harnesses up to the neck. Leaning toward a broken solder connection in the rear ECM. Seriously looking into a datalogger to connect to track the sensor voltages/grounds over operating time before replacing the rear ECM. Not much support in this part of North America for these machines.
  8. GaryHoff
    Feb 26, 2009
    750
    Alberta, Canada
    Front and rear ECMs should be the same, but with different software. You could swap them for testing purposes. Any exact fault codes would help. You may also want to swap the throttle pedals for testing first.
  9. gearhead74
    gearhead74 Member
    Mar 20, 2020
    7
    theodore,sk
    hello did anyone ever come up with a good fix for theses terex scrapers with the driveline issues ?there is three here all with 5.9 cummins all 2006 all three have broke driveshafts yolks ,couplers , we replaced anything that was worn out had heavier driveshafts made and balnced yolks made up heat treated was stilll cheaper than buying one from terex ,but yet with all this done all three machines continue to break ,the new heavier driveshafts have not failed now its the u joints ,yolks or inout shafts on engine and transmisson side always front engines never the rear
  10. Questionable wizard
    Feb 10, 2018
    71
    Ohio
    I'll add on to the other post you made the other day. There were less than 70 TS14Gs built with Cummins(strike one for product support- low numbers). Terex bailed on the scrapers after the last recession other than selling parts. There is no service support from the OEM, no terex dealers, all technicians have scattered(strike two). I believe the scraper and terex trucks parts are now owned by Volvo group(strike three). Somebody please correct me if that's wrong. So you have a product that few were built, no support, and a competitor/owner which is allowing the product to die the slow death.
    The problem I explained in your other post, the Cummins engine rotation at idle, is not smooth(engine problem). There is a speed up and slow down every revolution of the crankshaft. Like Gary mentioned and I relayed, the jerkiness of the driveline is reduced at a faster slow idle(i.e.- 950rpm or better).
    You could make the heaviest drive line possible and the next weaker link will break(you have to solve the root cause of the problem-a different driveline is only a bandaid). Making sure the drive coupler is in good shape, and increasing your slow idle will solve most of your problems.
    The only other thing you might try is contacting Cummins to see is there is another QSB engine application which uses a heavier flywheel, but then you may have issues fitting the drive coupler inside the pump drive housing. It wouldn't be hard to make a thicker spacer ring for the flywheel housing to accommodate a wider flywheel.
  11. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,020
    Mechanic/welder
    Wherever I end up
    Is there room outside of the torsional damper to bolt on a ring of metal to add mass to the flywheel? It would have to be balanced with the flywheel of course.
  12. mountainguyed67
    mountainguyed67 Well-Known Member
    Jun 5, 2017
    210
    Fresno, California, USA
    This is Terex response to my asking who to get loader parts from now. I don’t know if scraper and trucks are owned by the same company, email information below should get you an answer.
    1-28-2020
    They now belong to Mecalac 888 632-2522.
    Also, driveshafts might break if front and rear aren’t being driven at the same speed/ratio.
  13. gearhead74
    gearhead74 Member
    Mar 20, 2020
    7
    theodore,sk
    hi and thanks for the reply back i am blow away that there were less than 70 of the ts 14 gs built with 5.9 cummins they definetly have not been very rleiable thats for sure
  14. gearhead74
    gearhead74 Member
    Mar 20, 2020
    7
    theodore,sk
    he
    llo are the ts 14 g s with the 6.7 cummins are they having driveline issues as well ?or this a better engine than the 5.9 cummins
  15. Questionable wizard
    Feb 10, 2018
    71
    Ohio
    I was not aware Terex installed 6.7L Cummins. Last one off the line was August 30th, 2010. I'd have to look up when the 6.7s were introduced by Cummins. The advertising doesn't mention anything about them, only 5.9. I've seen one for sale which the picture of the engine serial number tag showed 6.7L. Possibly a replacement engine. I don't know the idle characteristics of the QSB 6.7.
    I'm in the middle of rebuilding the transmission in our G. After seeing the size of the clutch pack plates and discs, I wouldn't want to put any more horsepower to them. They are maxed out! I know somebody in NZ who replaced the Funk DF150 transmissions with DF250s because he had so much trouble. But he operates in some pretty steep terrain with 12" sideboards on the bowl.
    The S17E used the DF250 transmission.
  16. Questionable wizard
    Feb 10, 2018
    71
    Ohio
    The Cummins machines started at S8531011 I believe in 2005. The highest S853XXX I've seen for sale was S8531049. 2007 or '08 started the S914XXX machines at S9141011. The highest one I know of is S9141020
    No other machines on the market to compete in this class.
    If Terex had maintained a reliable owner and kept refining the TS14G's, they'd had a superior machine. The refinement was sputtering to a halt in the early 2000s. The reason the Cummins were installed was they were certified to meet emissions. The contract for Navistar to supply Detroit engines ended about 2003- '04.
  17. mountainguyed67
    Jun 5, 2017
    210
    Navistar made Detroit Diesel engines?
  18. Questionable wizard
    Feb 10, 2018
    71
    Ohio
    Detroit 40 series were rebadged Navistar DT466E 1999ish- 2003ish
    RZucker likes this.
  19. gearhead74
    gearhead74 Member
    Mar 20, 2020
    7
    theodore,sk
    hi and thanks for the reply ,i am not sure what to about these three scrapers would be nice to put a bigger flywheel to take the rattle out of engine ,but then again would that fix the problem and where would one start lol
  20. gearhead74
    gearhead74 Member
    Mar 20, 2020
    7
    theodore,sk
    we were also talking yesterday about possibly installing a different engine all together in these and scrapping the cummins but then with all the electronics where would you begin with that swap over ,an old screaming detroit in there would be kinda neat but then would have to put pedals in cab for throttle etc
