William Creek
I think my problem is in the same area. I was working on the driveway and the blade angle hydraulic cylinder was leaking badly. I stopped the machine, removed the cylinder and had it repaired. Reinstalled it, fired up the machine and everything was fine for about 30 seconds. Clutch pressure then fell to zero. A large quantity of hydraulic fluid was flowing from beneath the engine but I am unable to locate the source. The main hydraulic tank is absolutely full The fluid level stick under the floor plate is on "add fluid". The blade vertical movement works just fine, but the tracks . . . not an inch in forward or reverse. It's pretty clear something is leaking badly, but where do I start looking?
