gnebgen
I Have a 1978 TD7E with the 6 way blade. I purchased cylinder seal kits for the 5 cylinders. I am starting with the worst leak which angles the blade. I am unable to get the end cap to turn.. Have a 3 foot pipe wrench with a 2 foot cheater pipe. I tapped on it with a 2 lb hammer and also tried to get some liquid bolt buster in the opening. I also used a chisel in the cut on the cap and used the 2 lb hammer, but will not move. I also heated it some, but did not want to melt any of the old seals inside. Any other suggestions to get the end cap off. I have left it attached for now as it is easier to try to remove while attached. When I remove it I will have to cut the bolts holding the pins as they have never been removed. Per the previous owner, at 4000 hours the seals have not been changed since the factory. Thanks.
