Tb180fr advice
Don.S
Montreal Canada
My just picked up a new to us tb180fr serial # 178400550 that has just over 4000 hours on it. I will be the guy in the seat most of the time and I also do the maintenance on everything. We have never had a machine with this type of offset boom. The previous owner put a valve in the automatic track tensioning system because he said it was always too tight .
I would love to hear if anyone has any advice, tricks or thoughts for us about this machine. Thanks for everyone's time.
heymccall
Western Pennsylvania
#1...I cannot keep fanbelts tight. Every 300 hours, I find myself retensioning the alternator belt. If s/n is 1783####, then a pry bar must be used. If 1784####, then there is a jack screw to aid. Verify belt tension by attempting to turn fan blade with 1 finger. Turns= adjust belt. 300 hours just happens to be my oil change interval, too.
#2 AC belt uses idler pulley. If adjusting alternator belt, loosen AC belt and spin idle pulley. Smooth and wobble free it should be. Pulley bearing failure is usually around 3k hours.
#3 Adjust slewing arm vertical pin clearance as needed. Boom pushing down, air gap under slewing pins should be .030 in or less. Raise boom off ground, loosen jam nuts, turn Allen heads in until stopped, then back out 1 flat (60°). Same for inner slewing pin clearances. If greased somewhat often, not required but every couple thousand hours.
#4 Hydraulic filler plug is 1-5/8". Depress vent button on breather before opening filler. Level to be checked "chrome in", unlike Caterpillar. Don't overtighten.
#5 Oil is cheap. Change 90W in travel motors at least every 500hr. Nobody I talked to can even reseal them, and they are expensive. Duo cone seals are available should they fail. Finding someone to put them in never materialized. Did them here.
#6 I run 10W TO4 spec hydraulic oil in all of mine. One just turned 11k hours. No hydraulic issues from using that oil.
#7 Pump outlet fittings always seem to loosen or leak. With cab up, a 1-1/4" wrench can tighten the jam nuts. Orings need replaced if continuing to weep. Must be metric or Takeuchi, SAE is wrong cross section.
#8 Learn how to enjoy the full radius feature (the FR in the model number). To rear of blade lever is "S,L,M" knob. That is for cab protection from bucket intrusion. At every startup, machine defaults to Wide bucket, regardless of knob position. When in Wide, boom will not go back fully, when slewn (slewed?) fully to the right. Rotate knob fully thru each position CW, then CCW, and set to "S". Slew boom fully to the right, then fully raise boom, FULLY, all the way back. Just watch for cab to bucket interference the first time you try this. If bucket is too wide, or system is screwed up by previous owner, either the cab will be struck, or the boom wont raise all the way over. Use "L" or "M" for wider buckets. "S, L, and M" are width defined in the operator's manual.
Any more questions?
uffex
Lincoln UK
Admin
Good day Don
Life is foe learning and your comment that you have automated track tension valve is new to me can you post any information on this device. We have a source for TB135 operators manual available I guess much is about the same I could ask for a extract if you believe it may help you, if so drop me a line.
Kind regards
Uffex
heymccall
On the TB180FR, rather than conventional grease jacks, this machine uses a regulated hydraulic pressure to hold each track in tension. To loosen track tension, for service, a hand wheel (Allen set screw w/ jam nut on later models) on the track cylinder is opened.
To tension track back to spec, tighten hand wheel on cylinder, then operate machine in high travel mode.
My TB53FR does not have this feature, but my LeeBoy 7515 paver does.
uffex
Lincoln UK
Admin
Many thanks Heymcall
That clears my question in a very prof way.
Kind regards
Uffex
Don.S
Montreal Canada
This is a steel track machine. So with the track system can I choose how tight or loose I want them or does the machine do it all. Also is the system pretty good or is the previous owner onto something with his valve to keep the tracks looser.
Don.S
Montreal Canada
What width buckets do you use? We dig in everything from very soft silt to areas that are just rock and the only thing done there is apple and sugar bush.
Don.S
Montreal Canada
Also we are able to touch the bucket teeth to the boom cylinder is this normal on this machine or is something incorrect.
uffex
Lincoln UK
Admin
Good day
Often the quick couplers installed are not an original item in the design of machines if you have one it can increase the turning radius of the bucket which results in the bucket being able to excavate your boom cylinders.
Kind regards
Uffex
heymccall
Coworkers completely destroyed boom cylinder rod guard on all four of my TB180FR machines, and our TB53FR.
I've got Geith and Strickland hydraulic couplers on all of the TB180FRs, and a Werkbrau mechanical on the 53. (We'll discuss why to never buy a Geith coupler another time.)
Surprisingly, even though all of the rod guards were destroyed (and scrapped), I havent had any cylinder damage to any of them (the TB180FRs).
My TB53FR got so bad (and expensive) that I shortened the arm cylinder barrel by 1.5". Voila! No more damaged boom cylinder. It did sacrifice a little of the FR, but, on my 53, I seem to always encounter operators who have zero clue that the boom will go back that far anyways.
Since you asked, I can't help but wonder if yours isnt already missing the guard?
Don.S
Montreal Canada
So after putting some hours in the seat of this machine I am very happy with it. The FR feature sure makes it feel like a smaller machine whenworking in tight places. Over all we are very happy with this machine.
We have a 24 inch digging bucket and a 45 inch ditching bucket but I feel like both of these are small for the machine. What do you guys think?
Don.S
Montreal Canada
s?
I am having a brain fart and do not understand what you saying here. I guess I will have to take a closer look at the machine and figure it out.
redranch
Mt
i know this is an old thread but thought maybe someone can help me out. I have the same machine and for the life of me I cant find a ac belt for it. Didnt have one on it when i bought it, have searched internet a lot. No dealers here close in Mt .It is a 1784#### and has the 4tnv98 Yanmar. Also where are you guys buying parts for these things if need something major?
suladas
For the fan belt on my 153 dealer didn't have or know specs, I just had to measure it and got one at NAPA, any automotive place should have a belt that matches i'm sure.
heymccall
Well, the 1783#### is definitely different than the 1784#### series.
I finally wrote down what I used on mine.
To get the AC belt on, I have to remove two of the 3 idler pulley bracket bolts.
EX005 is my fleet unit number.
heymccall
Takeuchi is only $45 for belt.
You can use andersonequip . com to look at pricing. I don't believe you need a log in.
