My serial is 14510745.
Excuse my ignorance...Im not very experienced chasing down electrical issues - but when you ask if I have B+ or ACC, do you mean do I have voltage at those locations?
Where do I measure for those? Is both B+ and ACC on whats labeled "Starter SW" on the schematic? Is that on or near the starter itself? EDIT: nevermind I just realized thats got to be the key, right? Starter Switch would be the key I assume...
Some of my fuses appear to have power and some do not. For instance, the Cigar Lighter/Wiper, Stop Solenoid, High Speed Travel all measure voltage. However when I test the 20A for the "Lever Lock", I get nothing. Same with the 15A for "Solenoid A,B".
Looking at the schematic, it appears the fuse box is broken into 3 sections with each section being fed from a different source...the top section (in schematic) is fed from ACC, bottom from B, and the middle section fed directly from a fusible link.
