hargrove
Any one ever changed system 1 back to old style undercarriage
Converting a machine from System One back to the conventional heavy duty u/c is very simple. The only machine that is not able to convert back is the D6K dozer.
I would imagine that parts for the D6K will be available soon. When converting a high track dozer back remove the guards around the idlers and change the roller guide wear strips due to the HD track being wider. The idlers also need the spacers removed from the idler mounting brackets. Very simple procedure.
Can someone explain to me what "system one UC" is? Why is it so frequently talked bad upon? What year machines its on?
Etc
Just trying to learn more about it not start a debate thanks guys
