I hope I can make myself clear. I have a SA Mack dump. The trailer hitch consists of a very heavy plate with the D rings . trailer plug and a channel for a 2" receiver. I curently am using a 2 5/16" ball which I want to change to a pindle type hitch. In doing so I want to buy/make a shaft that will allow me to pull the shaft out and move it side to side to make hook up easier. It's a PITA to get the dump lined up the trailer now.
What I have in mind is a solid shaft, approx. 3-4' long with a hinge about 12-14" from one end. The hinge will have to fit inside the receiver tube. The other end will have a number of holes to allow a pin to be inserted to stop the shaft from being pulled out too far while allowing the hinge to clear the end of the tube. Once the ball/hook is positioned under the hitch and hooked up, the truck is pulled ahead to get the shaft straight and then backed up, thereby sliding the shaft back into the receiver tube with the hinge inside the tube. Retaining pins would be inserted as normal.
The hinge would need to be strong enough to support my 20' tandem trailer with a 1845c SS and implements for the short time required to make the hook up.
Has anyone seen something like this or know where I might get one?
I know there is a commercial hitch of this type made by Schuck. That unit while being expensive, would also mean extensive and expensive cutting and welding of my existing hitch plate
