crane operator
All that black nasty crap is straight from your fuel tank that's in the picture of your sediment bowl. You need to drain the tank, clean it out, and treat your fuel for a while. There's going to be a lot of fuel filter changes in your future.Here is the sediment. It was full before this picture. Took awhile to drain.
Also, there's no gas involved here, stop saying it. Call it fuel or diesel. Gas is not a interchangeable term for diesel.
And I guess you need to do a little studying on diesel and water. If you can't tell the difference between diesel and water - see, smell, touch, and taste it. You keep tasting it, you'll learn to differentiate it by the other means.
The idea here is that the water will end up in the bottom of the tank, and the bottom of the fuel and water separator filter bowl. Fuel floats on the water. So you are opening either valve to get rid of the water, rather than making your filter absorb it all. Draining it off is cheaper than making the filter catch it. You want to stop all water from getting into the injection system. It will ruin things. You want to just drain off the water, not drain out fuel.
I think you have two problems here, the machine loses prime over time, making it have to crank a bunch to get going. And you've got a algae/ contamination problem in the tank, which will continually clog your fuel filters.
The priming issue, you could just try pumping the manual priming pump every time you go to start it, after its been sitting. Or pressurize the system to figure out where the air is getting in and fix that hose/ oring leak. Or just replace everything from tank to engine. All the lines, and o rings sealing the system.
The tank contamination is going to take removing the fuel out of the tank, cleaning the tank as best you can, and then get a fuel treatment to kill any algae growth you might have. Its hard telling from the pictures what exactly is coming out of that tank, but its not good stuff.
