ibc, when you install the fuel lines to the injectors put a drop of oil on the flared end between the flare & the nut, it helps to keep from cracking or twisting the line. Torque the injector hold down to 30 ft.lbs.& the fuel ines to12 ft.lbs.
The 4-53 looks like it has a woodward hydraulic governor. The woodward is alot more responsive than a regular mechanical variable speed governor. you'll have to make some adjustments to it when you get it in the BE. I don't know what high Rpm on that gen set is as it probably a 400 Hertz gen set.
If I can help, just let me know.
Mike
