lumberjack
Sounds like the only problems stemmed from them not sending the right product.
Looking good!
Looking good!
Looking good!
just curious how come you rented the 308 when you had the 334? size difference?
Lost yesterday due to waiting on the two isolator row structures that were left off the first shipment.
Thanks for the pics CM. So.....is the main purpose of this for storing rainwater and letting it flow out into the public storm system pipes at a slower rate? I know nothing about this as you can tell.
I just watched the video and noticed non-woven fabric on the bottom and woven on the top. Does one stop water and the other lets it pass through?
Ah yes the good old Stormtech System. Looks like u got it. A thing I like to do is put a screw in them so they dont pop apart as u are stoning them. They are not to bad after u get the hang of them. just a lot of labor to get them right. I have done both styles with structures and with out. it depends on how they are using the system. Did you have to put down plastic round the system?
CM1995 isn't it fun field cutting the ends to fit the pipe. I wish they would just send the right stuff.
This storm water system looks a lot like an infiltrator septic system. It looks like you went ahead with the install, despite the masons not being topped out.
Can you elaborate on the "love/hate" T250? The laser is too blury to make out but looks familiar. Which one are you using?
I have always wanted a 308 size machine. Right now it's really hard to justify when the old 416 keeps on going.
Nice pics...keep 'em coming.
Nice project CM,and thanks for the pics. Did you have to figure your rock quantity or was that provided in the design? I guess if you know the displacement of each it would not be too bad, but that looks like an easy place to loose if you goof that number up.
Around here I can see getting it all set up nice and pretty with fabric down and chambers in place and then having a nice 50 mph breeze come through. That is how my luck goes!
Sound like you will be able to pay for that pickup in no time if work continues to pick up!
CM1995 on the last system I did they had us put 30mil poly between the non-woven and the stone. not sure why because it was the first time we had to do it.
We toughed it out Friday until 10. Drizzling rain and 40 degree temps are miserable.:bash
We got one end of the manifolds "field cut" and installed and laid out the other end, tomorrow we'll finish up the field cuts. The ADS engineer is coming at 11 tomorrow to do a field inspection and give a letter stating everything is installed according to the spec's.
I plan on using a Garbro bucket attached to the forklift the GC has rented to place the anchoring stone between the chambers. Once that is done, we'll be using the T250 and 420 to place the stone backfill. In all I have figured 18 - 26 ton loads of stone to backfill the chambers 6" above the top of the chambers. Then the whole system is wrapped "burrito style" and another 12" of 8910, which is screenings, on top of that.
Nice pictures CM. Too bad there were missing parts though.
