melben
- Joined
- Jan 14, 2008
- Messages
- 1,029
- Location
- Williamsport, Pa
- Occupation
- Retired 50 Yrs with Case dealership
OK guys, I did a amp test on my Nippon starter with a non calibrated dash style gage and the solenoid drew about in the 10 amp range while cranking, I then took a Blue Point ohm meter and tested the solenoid coil ohms, 1.0 ohms, so applying ohms law to those figures the amps draw of the solenoid would be exactly what the system voltage is at the time of crank. So if the battery float voltage is 12.6 after sitting that is where the amps needed should be to hold adequate voltage at the tab, the cranking voltage will of course drop but there will need to be enough volts-amps to engage and keep the solenoid engaged.
That is not to say that it will not engage at less than that but that is the actual figures involved with that circuit by applying ohms law.
For the fact I was using a 0-30-60 amp gage I think the needle position was reasonably close to 10V cranking.
Just throwing this out for you guys to ruminate on, LOL.
Wuddya think guys.
Mel
Wuddya think guys.
Mel
