TOM V
The hydraulic torque wrenches I have are both HYTORC, XLT-3 AND AVANTI-10.what make is your hydaulic torque wrench
Tom, I noticed that you were adding the Hensley "top loader" type shanks to that excavator bucket. I have found this type to be a bit problematic. They often break the roll pin and the roll pin can be very difficult to remove (broken or not) when the center gets packed full of dirt. I have one 8" bucket for my TLB and the top loader is the only shank I can use when the (3) shanks are so close together. I have not found a good way to remove them once they are packed w/dirt. Even reverting to the torch is not very effective because the dirt inhibits the process of melting the roll pin. What do you do? I have found a pre-emptive measure that helps the removal of the roll pin. I inject silicone or RTV into the center of the roll pin prior to installation into the tooth and shank. The only real purpose is to keep dirt out and it remains flexible so it does not interfere with the way the roll pin functions. I little anti-seize, on the outside of the roll pin, helps too.
That's awesome they provided you a fork lift to use as a work platform.
Hey Tom V what brand of seal kits do you use for the excavator rams?
Of course they didn't Willie! Tom had it in one of those lockers on his truck!!
Here are a few more.
