Solving caterpillar th hydraulic problems
Baltoi Ionut
Romania Patulele
If the hydraulic controls work poorly, slowly, the problem is either from the gaskets in the hydraulic cylinders that are worn, or inside the PHS valves.
I had both problems, and look what breaks inside the valves, for those who don't know.
Those rings give way and the pressure is released.
It's a little tricky to get to them because the circuit strip has to be removed, and after repair it has to be re-soldered
