So anyone see or use these tires from Firestone with claimed 300% more wear?
barklee
I actually saw these on a new JLG at a rental yard today. They look like pretty hefty tires. Anyone find a price on these?
Speedpup
With a 300% better wear rate I would guess they are a good bit more to buy. Same tire size just different load ratings on what is listed. All I could find is request a quote online for pricing.
icestationzebra
This kind of tire has been rumored for years, seems that it is finally here. A lower profile tire with stiff sidewalls will allow for slightly higher capacities on the load charts, especially above ~45° boom angle. One of the limiting factors for telehandlers has been the tires, as they were and continue to be designed for road graders. Originally companies got around the flexible sidewall tires by using liquid ballast. The situation got worse in the 90's as rental companies put pressure on the OEM's to stop using liquid ballast due to high repair costs. This forced the use of more steel weights to make up the difference, which usually can't be put in the ideal locations, which necessitates even more weight - and as you can guess the GVWs went up. Now if other tire companies like Galaxy follow suit the prices shouldn't go up much. And hopefully they prevent a couple tip overs.
ISZ
Reel hip
I have had good luck with recapping and then filling the tire as solid. I don't know if this is an option in your size. I run Terex and a JCB 520 with very little wear on these RT lifts. Doug
aerolift
Tires
We run a fleet of 40+ SkyTraks. Tires and parts are a constant issue. We are very active investigating cost saving measures. We use and sell many used parts. While researching the new Firestone tires it was revealed that the existing rims will not accomodate them. This is a major negative and would create a whole new challenge keeping track of which machine had what tires and rims. Until they design them for the existing rims the tires have limited appeal to fleet owners.
I bought my tires exactly a year ago. The rubber has cracked along sidewalls and some spots have cracked and pieces of rubber fell off. I have never had this happen to my tires within a year. Will not buy these tires again.
