Justin Payne
Hello all. I own a Kubota U50-3@ year: 2006. There is some sideways play in the swing mechanism. I have had off the cover plate revealing the ring gear and swing motor gear. I lifted the bucket off the ground and had a friend push on the bucket the back and forth while I looked at the gear mesh. There was hardly any rotational movement of the swing motor gear. Almost all the sideways play is the result of play/clearances between the gear teeth. I see the gear teeth (specially the gear teeth of the swing motor gear) are somewhat worn. There is a clear notch along the perimeter of the wear surfaces. (see photo).
I would be very costly and time consuming to change the ring gear and swing motor gear. I therefor have the idea that if I could move the entire swing motor slightly outwards towards the ring gear, the gear lash /gear teeth clearances would decrease, and the sideways play of the excavator would decrease. I don`t know if the free holes in the upper chassis holding the swing motor give any play with the given bolts.
I hope I have managed to describe the situation and my thoughts so that people understand. Has anybody got any comments to this? I would be very appreciative.
