Don Shilling
It would seem the right clutch is slipping . Generally, when steering clutch problems arise it is best to plan on cleaning and overhaul for both sides. You'll be far ahead in the long run.Not sure if I am in the correct place but I just got a d65-12 machine has been sitting for several years. I got the machine started up and moving a little after changing all filters and fluids and had to replace all cables for throttle and shifter and drive control cables. Problem I am having with the machine is when in forward only the left side track pulls same goes for reverse it only pulls on left side. The right side will pull track tension in forward and reverse but has no power to turn
