Section for komatsu d20,21 and similar grey market dozers
cooberb78
Can anyone out there tell me where to buy a sleeve kit for d20p-5 with 4d94-2 engine. Been all over the net and keeps sending me over sea
attaboy
Exhaust Pipe Liner?
In the muffler replacement procedure, I have found within the Exhaust Pipe Tube (vertical tailpipe) a liner material akin to rock-wool or fiberglass mat, which was not very difficult to slip out, the tube being frozen in place .. the Hood off the tractor. I do not see a separate part number for this material, so I'm wondering is this is some previous owner's DIY installation? This also begs the question, what is supposed to seal the muffler outlet, to the bottom of the exhaust tube, which is about 2-1/4" larger in diameter than the muffler outlet tube?
Komatsu has done a superlative job in isolating normal engine vibration from the tractor, so obviously there has to be some non-rigid connectivity between the muffler and the hood, so what is supposed to be used to fill this inch wide void around the muffler outlet?
On a side note, I was doing some very heroic muffler patching of little holes, and then reached up and felt that there was ZERO muffler exhaust tube .. just a big hole. I figured just 30 years of corrosion from the open exhaust tube pipe allowing rain to simply run down inside. So with that I got a 2-1/2" Rain Cap to install, but with the open void I'd still have the Smoky Engine Syndrome noticeable briefly during startup, and the new cap would not be getting the benefit of the full exhaust flow.
I invite your comments, experience, and solutions to this rather unusual engine exhaust design, and Happy Holidays .. Safe Journey!
Drawing including 6144-11-5760 http://komatsupartsbook.com/#?k=!0!2!1116!678!1!8
Geardoc
A Google search will give you the full Factory Service manual for $9.95 on Tradebit.
I have tried buying manuals, scanning them, and then offering them for just enough to recoupe my money. I've always sent manual first and then if it helped, please pay $1 or $5(in the case of a $500 manual that was out of print and the company dissolved). No one ever paid.
Pay the $10 USD and get the manual.
http://lmgtfy.com/?q=komatsu+d20+d21+manual+tradebit
Jerwade
I have followed your advice on removing the steering clutch pack from my d20a-6 . It will rotate in the flanges
But will not compress enough to be removed.I can not force it back even enough to clear one side let alone both.
After two days of hammering I am at a loss. Any help I would be thankful .
spark
This is Spark, you have me mixed up with someone else as I don't know about a clutch pack on your equipment
darinray
Charter Member
Sorry to hear of your troubles. Here are a couple things..
take a large wedge and drive the inner drum inside the out drum rotating it in 180 degrees to do it evenly. WATCH it because they will come back in great force. I don't recommend doing the chisel wedge thing because it is dangerous.. I had one chisel fly back and actually went into my overhead door. YIKES>>> After that I cut the drums.. Instead of doing this I would cut the outer drum apart in sections to get everything out so you can get it back to work. No worries I have all of this in stock.. Contact me if you have any other questions or need anything.
Jerwade
I don't think I am quite ready to start cutting up good parts yet , am retired and labor is the cheapest
Thing I have.
darinray
Charter Member
:) I understand.. You see sometimes the clutches get stuck in the "wrong" grooves of the drum where the clutch teeth wear into it and its almost impossible to move the steel on steel with the chisel... BUT I can't blame you for trying. :) Take care and good luck
Dozman
keep in mind they're supposed to come apart.The way Darin explained it is the way I did mine. And a little side note if its that hard to get apart,Then everything inside is probable trash. (Just a thought):)
Willie B
There are books available for most machines. Buy them. Some are expensive, but worth it. I'd avoid engine oil in hydraulics.
Oldyellar
Need help
Hello everyone got problems with my komatsu d20a-6 it has been sitting all winter got it out today for first time everything was going great till all the sudden right track would lock up and stall engine going forward I could catch it before it killed engine put it in reverse worked fine then it would go forward fine for a while then the left side started doing same thing forward and reverse as long as I went opposite way it locked a few feet it would work fine for a while it seemed to lock up more under load so I'm at a lost is it steering clutches brakes or what any input would be greatly appreciated dozed is kept inside and was also wondering were exactly is the drain plug for the steering clutch housing
darinray
Charter Member
Oh man.. First thing i would do is back off the brake band clearance with the adjusting nut in the back of the machine behind the little caps. Also if you stored the unit with the parking brake applied the linkage may be froze and needs lube.. Check the be sure the brake actuator arm is moving in the released position. I've actually drilled and tapped the bearing housing with the arm goes through to keep those little bearings in there free.. You could spray with penetrating fluid but it won't last too long without either taking apart and cleaning unless you drill and tap for grease fitting.. Good luck and keep us posted..
Oldyellar
Will check brake linkage and adjustment as you said this weekend I hope that fixes it as far as parking break it wasn't applied but will let you know what I find this weekend
jillmd
Hi,
Has anyone installed a backhoe attachment to they're D20 or 21? If so, can you post some photos?
Thanks for the info.
Fat man
I have a d21a7 and am having starter problems. The solenoid is bad but it will not separate from starter. Do I have .to remove starter to get it off
