darinray
Charter Member
The serial number that I found under the seat is 06803
Your filter is on the tank on the right side right next to where you would add oil to it. Held on by 4 bolts and you can check that and or clean it. if it's your pump then you could have it check out or at least take a pressure reading off it. Hope you figure it out.
Darin
