RRRancher
That's a nice looking dirt pusher there, rdoiron. I sure could use a cab like that in the Texas summer heat. I hope you enjoy yours as much as I do mine.
The Rock, I don't know if you are having the same problem as I was, but it is something to eliminate anyway. Go back and read my post # 1507 and subsequent posts on that thread to see what I found out. If that doesn't do the trick, let us know and we can suggest other things to try.
RRR
Just wanted to give an update to my problem from above. I took the clutches out and found water had invaded the drives on both sides. Everything was rusted very badly. There was also enough dust in the drives that the clutches were running in it all the time. I suppose that is why the clutches would grab some of the time and not other times. I suppose replacing the brake bands would be a good idea too since I am already in there. Anyhow, a simple fix was not in the cards for me but, this really isn't a difficult job. It just takes a little time. I am thinking it may be a good idea to pull the plugs from the bottom occasionally to check for water and dust build up. Just thought I would share my experience in order to inform and hopefully help someone with their machine.
Silly possibly even stupid question. Does anyone know if you can put the 20" tracks from a D20P on a D20A? Also if it can be done do you think it would be worth it for the extra traction or would it be better to add to the grouser height or an extra grouser added to the rear of the track pad? I am asking because a, I only have about 2hrs of seat time on my D20A5 before I deployed and don't really have a lot of knowledge about what my dozer will do. and b, I am trying to plan on what I want to do to make it as useful as possible when I get back on it. I like to plan/day dream while sitting here in lovely Kuwait. I will be using it mainly in the hilly side of Ohio so sideslope issues may be an issue and old soft farm soil.
hey guys sorry to but-in but im new here trying 2 figure this forum out but i need some help thinken about buying a d20p-6 dozer and the right steering clutch needs to be adjusted how do i do this ????:beatsme
That is an interesting question. I don't know the answer. Hopefully someone can educate us. I know putting on wider track pads will give you a lighter ground pressure so it seems like that might be less traction. But then again the grouser is longer and the pad area is larger ?? I know with my dual wheel truck I get better traction in snow if I take one wheel off. The smaller footprint is better. I think a second or taller grouser will surely give you more traction but if the track slips a little it is easier on the drive train. On side hill operation I think the narrow track might be better. I would like to sink in a little I think.
I don't know any of this stuff. I am just thinking out loud. Be safe until you can get back for more seat time.
g_man
well the one that you are sitting on under seat is for final drive trane one under pedal clutch housing do you not have the plate on your.s machine will oil&lube points,?on my new dozer or should i say used dozer there 3 dipsticks one is under the hood which i know is the oil stick, then there is one right underneath the seat what is this one?and what is the one underneath the brake peddle on the right.Also what specific fluid should i use on each one.
thank you for your time and have a nice day
P.S how do i tighten my tracks
I'm new to this forum & heavy equipment. Last Monday I purchased this D20A-6 dozer from a individual that used it a couple times and then put it into a conex for storage. Dozer has 2300 hrs but it clearly has a newer paint job. A lot of over spray. The sprockets are not a points and the track rollers are not concaved. Could someone break down a quick list of things to grease, fluid change (types of fluid), track adjustments, and linkage adjustments. This dozer is heading to my remote cabin this January in Alaska. It looks like I don't have permission to download a photo. How can I get permission?
Here is a short video of my new (to me) D21A-7 starting on my pond project. I'm moving a large amount of ground uphill towards the house changing the overall grading. I'm very satisfied at how sturdy and tough this small dozer is.
http://youtu.be/shNl_2Wz6dA
