Thanks Darin and KT., I guess I will drain it and try straight 30w . I can't find 10W around here anywhere..I don't know whats in there now so better safe than sorry...I don't know if its the band or not , more like plates sticking together because when I press clutch it keeps pulling , after about 10 min or so it starts working right ?? it doesn't set up alot and its like that everyday if you are useing it everyday...I have adjusted linkage just like it shows in the shop manual , I just thought if it had the wrong oil in it , it might cause this...one more question if you don't mind...can you run hydralic fluid in the resovoir for the blade??? it says 10w oil also...Hope I'm not asking to many questions at once or repeating something thats been said before in the forum,,,,thanks again , Paul
